Larry_G's avatar
Larry_G
Tutor
Dec 16, 2017
Uninstall WNDA3100V2
Replaced the WNDA3100 adapter with an A6100.  The A6100 works great.  I just can't uninstall the WNDA3100 function.  I get repeatitive error messages: cannot find SETUP.RTF.  There is a setup.ini in the indicated directory path.  Have tried Windows uninstall and directly excecuting the uninstall in the WNDA3100v2 directory to no effect.
Any suggestions?
  • Hi,
    I realize this is a week late, but since nobody else is going to reply:
    Try re-installing the old driver and software. Hopefully it will fix the corrupt install and the uninstall will work.
    If that doesn't work, Revo uninstaller is a great free tool to uninstall things from windows made for this exact situation. A lot of people use a driver cleaner to get rid of the little bits left behind, but I don't think you should need that in this situation.
    Worse case scenario is that you will have to leave the software on your PC.
    Merry Christmas and good luck with Netgear stuff :)
    • Larry_G's avatar
      Larry_G
      Tutor
      Thanks.  The reinstall and uninstall worked.
