Kuvasz's avatar
Kuvasz
Follower
Aug 24, 2017
USB WiFi Adapter
I need to know if the Nighthawk C1900 WiFi USB Adapter will work with the Franklin Wireless R850 hot spot supplied by Sprint. I'm asking this question because a few months ago I purchased a Nighthawk router only to discover that it wouldn't work with Sprint. I'm currently using a Belkin USB Adapter that is not too effective in receiving the signal from the hotspot that's one floor below my music studio.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You are looking for something to receive wifi from the R850 hot spot?
    I have no idea what the C1900 might be. It isn't a Netgear model number. CXXXX usually means a cable modem.
    Maybe you mean AC1900. But that's a wifi speed thing, not a Netgear model number.
    I would not expect a router to act as the receiver from a wifi source, unless you turn it into a wireless repeater. Routers are there to send out wifi. Not receive it.
    But maybe I don't understand what you are trying to do.
