Jonesarob
Dec 06, 2017Aspirant
W9CE 3001
Hello, is there an eqivialent to the netgear wireless internet adappter WNCE 3001? I wish to connect a CCTV system to the internat via the router. Therefore looking to find an adapter (plug & play), ...
- Dec 13, 2017
Hi Jonesarob,
We only have the following wireless adapters without drivers needed for installation.
WNCE2001
WNCE3001
WNCE4004
michaelkenward
Dec 07, 2017Guru - Experienced User
That's not how wifi adapters work. They need software and drivers.
If you already own a CCTV system, ask the makers how you can connect it to wifi and the Internet.
If it can connect via Ethernet then you could try this:
Powerline Networking | Powerline Ethernet | NETGEAR
- JonesarobDec 07, 2017Aspirant
Thank you for reply, though as I understand the W9CE 3001, did not have a driver. It was confirgued to your router direct, then was then inserted into the device. which then connected back to the router via wifi. Therefore no need for down loading drivers. Therefore was asking is there anything out there that is similar.
- JamesGLDec 13, 2017NETGEAR Employee Retired
Hi Jonesarob,
WNCE2001
WNCE3001
WNCE4004
- JamesGLJan 02, 2018NETGEAR Employee Retired
Hi Jonesarob,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
