Kansan
Oct 05, 2015Aspirant
WG111v2 add antenna mod
I got usb wifi WG111v2 at home but can't get the signal good enough and I decide to add (solder) the antenna on usb wifi but I am not sure where do i solder the 'active' and shield/ground of the coax cable/pigtail?.
I am guessing its either one of the j12 or c82 points. not sure however, is there any way to tell? guess etc? Thank you in advance for your help.
PK
(NETGEAR FAN)
My USB Wifi WG111v2
My Antenna
- JamesGLNETGEAR Employee Retired
Hi Kansan,
Welcome to Community!
These are the only information I can provide.
http://hackaday.com/2006/07/15/usb-wifi-external-antenna/
http://www.backtrack-linux.org/forums/showthread.php?t=3762
JamesGL
Community Team
- KansanAspirant
Thank you for your reply
