oliverop7
Jan 07, 2017Follower
WG111v3 not working on windows 10.
Hello.
I have been using my WG111v3 on windows 10 fine until today it suddenly cut out. The blue light would only flash when I plugged it in and it wouldn't connect to "NG_Profile". Can anyone help?
Hi oliverop7,
The WG111v3 does not support Windows 10.
http://downloadcenter.netgear.com/en/product/WG111v3#searchResults
- JamesGLNETGEAR Employee Retired
Hi oliverop7,
Hi oliverop7,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
