Chopchop3
Sep 17, 2015Aspirant
WG111V3 Wireless-G Won't Work With Windows 10
I can't get the USB adapter to work with Windows 10 so I ran an Ethernet cable to go online and tried to update the driver for the USB adapter. The driver version says " 62.1181.1118 2009 " and Win...
Chitown18th
Jul 06, 2016Initiate
- natesuniverseJul 09, 2016Initiate
I also did a install using the 2.0 software but used Win 7 compatibility mode. This seems to be working for now. Otherwise just point the driver search to the download from the above link from device manager and should work through windows. I like having the options of the software too though.
