eraahad
Jan 02, 2017Aspirant
WG311T Installed on Windows XP
Yes the PCI adapter is available in device manager and works correctly according to it. The troubleshooting button does not work, it is pointing to Window XP Home edition which does not work. The...
JamesGL
Jan 02, 2017NETGEAR Employee Retired
Hi eraahad,
Try changing the security to WEP as the device may not support the WPA.
