eraahad
Jan 02, 2017Aspirant
WG311T Installed on Windows XP
Yes the PCI adapter is available in device manager and works correctly according to it. The troubleshooting button does not work, it is pointing to Window XP Home edition which does not work. The...
eraahad
Jan 03, 2017Aspirant
Interesting statement, "the device may not support the W2PA", do you have any specifications of your products?
It worked before I did the 67 updates of XP.
JamesGL
Jan 18, 2017NETGEAR Employee Retired
Hi eraahad,
Have tried changing the security option?
- eraahadJan 22, 2017Aspirant
The CH7486E Wireless Voice Gateway does not support any versions of encryption. Do you have any other idea?
It should say:
The CH7486E Wireless Voice Gateway does not support any lower level or versions of encryption
- JamesGLJan 30, 2017NETGEAR Employee Retired
Hi eraahad,
Try connecting it on a different wireless network and check if the same. Check with windows as well for any compatibility issues with security.
