tjrobinson2000
Aug 02, 2017Aspirant
Why do I have two networks with one wireless to ethernet adapter and a switch?
Here's the situation. I'm using a wnce2001 wireless to ethernet adapter connected to a gs605 switch. Computer is connected to the switch along with the printer. Wireless connection is to a mobile ...
- Aug 08, 2017
Resolved the issue after getting a new isp setup. Printer is now on a router and is working. Thanks for the reply.
JamesGL
Aug 08, 2017NETGEAR Employee Retired
Hi tjrobinson2000,
Check the connection of the Printer. If the network is on 192.168.43.0 then the printer should have the same IP range.
- tjrobinson2000Aug 08, 2017Aspirant
