Rickyzg
Aug 21, 2016Aspirant
Wifi a6210 doesnt show 5ghz
After I changed on router to 5ghz my adapter a6210 doesnt see my wifi connection, I tried uninstall, change in wifi adapter preferences. My roomate sees on her mobile phone but I dont. Any help?
Rickyzg
My wifi adapter doesn't see router SSID on 5Ghz, it doesn't show anywhere on my computer. Wifi adapter is Netgear A6210 "
802.11ac Dual Band with High Gain Antenna
Your PC at the Speed of AC. Now Faster with USB 3.0
When it comes to connecting online, speed is everything. Now with this AC1200 USB 3.0 adapter, you can make even your older Windows®-based laptops and desktops connect at the speed of 802.11ac, the world's fastest WiFi technology. Increase range with high gain antennas, and with USB 3.0, you can connect even faster than USB 2.0. Just plug this adapter into a USB 3.0 port and enjoy faster browsing, streaming and gaming. Compatible with USB 2.0 and the latest 11ac WiFi devices and backward compatible with 802.11 a/b/g/n devices."
VE6CGX
Aug 21, 2016Master
So, which old laptop might have a USB 3 port?
- RickyzgAug 22, 2016Aspirant
Tried on usb 2.0, 3.0. I have change back to 2.4 ghz on router. Now I have problem with my wifi always disconnecting. My notebook works fine with wifi, doesn't disconnect, but my PC with Netgear A6210 adapter disconnects every minute. In my UPC Ubee router settings wifi is set to 2.4 ghz , 20 mhz only, channel 11, mixed 802.11 b,g,n mode.
