VKennisovitch
Mar 12, 2016Aspirant
Wifi adapter A6100 lag spikes / disconnecting
Hi, I have bought a computer on a store online last month and I needed to buy a USB wireless adapter so I bought this A6100 WiFi USB Adapter. Since I've been able to connect to the internet, I've...
- Mar 16, 2016
I have decided to buy a cable and everything works fine now. The adapter was faulty since the beggining... I will send it back to the shop where I bought it and try to get a refund or at least a replacement..
Thanks for your help !
JamesGL
Mar 15, 2016NETGEAR Employee Retired
Hi VKennisovitch,
Is your laptop Windows 10 as well? If yes, try to install the adapter on the laptop and observe the connection. Make sure that the driver installed is for Windows 10.
