VKennisovitch's avatar
Mar 12, 2016
Wifi adapter A6100 lag spikes / disconnecting
Hi,   I have bought a computer on a store online last month and I needed to buy a USB wireless adapter so I bought this A6100 WiFi USB Adapter. Since I've been able to connect to the internet, I've...
  • VKennisovitch's avatar
    VKennisovitch
    Mar 16, 2016
    I have decided to buy a cable and everything works fine now. The adapter was faulty since the beggining... I will send it back to the shop where I bought it and try to get a refund or at least a replacement..
    Thanks for your help !
