mrfedora
Jul 21, 2016Follower
wifi device not found during install
Installation went well, to a point. Found upgraded software and downloaded it via a wired connection. . During final part of install; prompted to install the adapter. "Adapter not found".. Plugged...
- Nov 11, 2016
see other posts. run the standalone version from your downloads and conntect via settings. Thanks to SShikles in another string.
JamesGL
Jul 28, 2016NETGEAR Employee Retired
Hi mrfedora,
Have you tried to install it on a different computer and check if the same problem?
JamesGL
Community Team
