JanitorMom
May 11, 2026Aspirant
Wifi extender drops WNA1100 N150
I use NETGEAR WNA1100 N150 Wireless USB Adapter. Recently for about 2 months now it has been dropping signal. I have 2 WIFI's in my house hold ATT and Spectrum. ATT is fine, but Spectrum it keeps goi...
May 11, 2026Guru - Experienced User
Turn OFF one of the host WiFis in the house hold. Having two maybe causing interferences. Also turn OFF the extender as well and see if the issue continues.
Seems like you have too much wifi signals going on there and adapter can't handle all the noise.
Also ensure latest driver is installed for the N150 adapter.
Try using channesl 1 and 40 or 11 and 48 on the host router that provides the primary WiFi.
JanitorMom
I wish i could but one is my moms WIFI and one is my dads. So I am really stuck like that. Both are on opposite ends of the home though. Also need the extender otherwise I get 0 wifi signal at all. I updated a while back for the adapter but still same issue. Also no idea how to change channels cuz SPECTRUM is my main issue wifi. Been using this extender for like 10+ years. This is the only time I have an issue. Due to SPECTRUM you cant change anything but the password or the WIFI's name with the new routers and stuff.
- FURRYe38May 12, 2026Guru - Experienced User
If you have both wifi signals running, try putting one system and channels 1 and 40 and set the other to 11 and 48 for 2.4 and 5Ghz frequencies. Ask the ISP to help you change the channels.
I would keep the extender OFF for now as that maybe causing issues.
- JanitorMomMay 12, 2026Aspirant
Sadly with both WIFI I can't change anything, but the name and password. With out the extender I get no signal from either WIFI. So I am very stuck with this. Also what is ISP?
- CrimpOnMay 12, 2026Guru - Experienced User
ISP is shorthand for Internet Service Provider (AT&T or Spectrum)
