JanitorMom
May 11, 2026Aspirant
Wifi extender drops WNA1100 N150
I use NETGEAR WNA1100 N150 Wireless USB Adapter. Recently for about 2 months now it has been dropping signal. I have 2 WIFI's in my house hold ATT and Spectrum. ATT is fine, but Spectrum it keeps goi...
May 12, 2026Guru - Experienced User
You put what USB wireless device you have but not what "wireless extender" you have.
Or are you just referring to the USB device as an extender? (bad nomenclature)
eitherway its time to get rid of that USB device. Its ancient, slow, and bottlenecking your PC big time.
A cheap USB AX device can be picked up for around $20 and will greatly improve speed, stability, latency.
Very much worth it with the setup you have.
Normally I don't advise throwing away working equipment, but in this instance, its time to update.
