andywalters
Sep 21, 2025Follower
Wifi USB Adapter for Linux (Mint)
Hi all, I live in Australia and am in need of a Wifi USB adapter for Linux (Mint). I am a Junior Linux user so would be great if it works out of the box. But I do know how to use the terminal if ...
CrimpOn
Sep 21, 2025Guru - Experienced User
I have used several models of Panda WiFi-USB adapters on Mint Linux. The major consideration appears to be whether monitor mode is a requirement. If not, my guess is that almost any WiFi adapter will work. (If you are not sure what monitor mode means, then it is probably not a requirement.)
Just purchase one from a vendor that has a liberal return policy, such as Amazon, Best Buy, etc.
Perhaps check the Mint user forums?
