jmggmark
Dec 29, 2016Follower
will my WNDA3100v2 N600 Wireless Dual Band USB Adapter work with my Samsung smart led TV?
- Jan 02, 2017
Hi jmggmark,
It does not support Samsung Smart TV. If your smart TV has ethernet port, try WNCE2001, WNCE3001 or WNCE4004.
JamesGL
Jan 05, 2017NETGEAR Employee Retired
Hi jmggmark,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
