xunisys's avatar
xunisys
Windows XP Installation aa6210 (error 6210)
If you are lucky/smart enough to still be using a windows XP system and you hit error 1628 you need to bypass the autorun on the CD and go directly to the SETUP.EXE  (on the CD). All will be well.
1 Reply
  • Also when you plug in the adapter the install will go to network and ask if you want the new driver.   Absolutely do this
