cbrookhart
Aug 15, 2015Aspirant
Wireless Adapter WNA 1100 crashes computer
I just setup AT&T Uverse service and was given a Netgear WNA 1100 to use. The only thing the product has done is cause Windows to crash with an error: IRQL_Unexpected_Error. It started doing this whe...
cbrookhart
Aug 16, 2015Aspirant
Can anyone help me with this?
I have downloaded the Windows 8 software from netgear and installed it onto my Windows 8 desktop. The minute I enter the network key and click next, Windows instantly crashes.
- JamesGLAug 19, 2015NETGEAR Employee Retired
Hi cbrookhart,
Try to install the driver of the adapter manually.
1. Remove the software and driver installed on the your computer
2. Install the USB driver version (Supports Win10).
3. Once installed manually update driver software. Open Device Manager , select the WNA1100, right click , select Update Driver Software.
4. Choose Browse my computer for driver software
5. Choose Let me Pick from a list of device drivers on my computer
6. Select the one with NETGEAR INc.
JamesGL
Community Team
