mturonek
Nov 13, 2016Follower
Wireless Adapter
My LG Smart TV needs a wireless adpater to connect to wifi. I purchased the AC600 adapter and the installation CD is not working on my MACBook Pro. I am not sure the steps I need to take to make th...
- Nov 15, 2016
Hi mturonek,
The adapter only works with Windows based OS computers and not compatible with Smart TVs.
JamesGL
Community Team
VE6CGX
Nov 13, 2016Master
Is the adapter only PC compatible?
- JamesGLNov 15, 2016NETGEAR Employee Retired
Hi mturonek,
JamesGL
Community Team - JamesGLNov 20, 2016NETGEAR Employee Retired
Hi mturonek,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
