Mariapaola
Feb 11, 2019Follower
WNA 1100
I can't install the Adapter because my CD driver is broken and I need to install NETGEAR n150 Wireless USB Adapter
1 Reply
There is support for this device, including manuals, at the end of this link:
>>> WNA1000M | Product | Support | NETGEAR<<<
You can download the software for your operating system there.
If you are using Windows 10, it may have them built in. Then again this is an old adapter and might not work in Windows 10.
