mpharis3
Oct 10, 2017Follower
WNA 3100 Adapter Windows 10 Failure
So here we go, this post is going be a few weeks worth of frustration over a device that just does not seem like it wants to work. A few months ago I purchased this little device and after installatio...
- Oct 26, 2017
Hi mpharis3,
Did you use the drivers here?
https://www.netgear.com/support/product/WNA3100.aspx#Software Version 2.2.0.4 (Supports Win10)
Do you have other computer to install the adapter and check if the same problem?
JamesGL
Oct 30, 2017NETGEAR Employee Retired
Hi mpharis3,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
