albert1946
Jul 29, 2016Aspirant
WNA 3100 Wifi adapter with windows 10 operation system
Hi I have problems with the Netgear USB adapter WNA 3100 with windows 10, after 2 or 3 days I have no connection to the router.After reinstalling it works for 2 or 3 days !! Windows trouble shooti...
JamesGL
Aug 05, 2016NETGEAR Employee Retired
Hi albert1946,
Try installing the standalone driver instead of the Genie version.
JamesGL
Community Team
- albert1946Aug 06, 2016Aspirant
Hi
Thanks for your answer, I'll try the standalone version and will see what the computer will do
Greetings Albert
- JamesGLAug 10, 2016NETGEAR Employee Retired
Hi albert1946,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
- RedtheboldFeb 05, 2017Aspirant
I am using the standalone version on my windows 10 pc and it works okay. However, I do have an issue where my adapter loses connectivity. I have checked the router and the router does not seem to be the issue because I have another windows 10 pc that is using the same exact model adapter without issue.
