east56user
Sep 20, 2015Aspirant
WNA1000M G54/N150 wireless USB Micro Adapter - Windows 10 Update?
Is there a Windows 10 update for the WNA1000M G54/N150 wireless USB Micro Adapter? I checked Netgear tech support and it only listed a Windows 10 update for the WNA1100 USB Flash Adapter.
JamesGL
Sep 22, 2015NETGEAR Employee Retired
Hi east56user,
For now below is the link for the list of adapters that will work with Windows 10. It will be updated once there are additional adapters that will work with Windows 10.
JamesGL
Community Team
- east56userSep 29, 2015Aspirant
Hi JamesGL,
Thanks for your prompt reply and the link to the list of Netgear adapters that have a Windows 10 upgrade available.
However, prior to my request for help, I had previously discovered the same list. Unfortunately, the list did not include WNA1000M G54/N150 wireless USB Micro Adapter.
After further researching Netgear support I found a Windows 8.1 update for the WNA 1000M G54/N150 wireless USB Micro Adapter which I decided not to pursue.
Instead, I hovered over the Netgear WNA 1000M Genie program Icon link and clicked on properties. Next I selected the Windows 7 compatibility troubleshooter that made it possible to have the Micro Adapter function with the Windows 10 operating system.
Presently this temporary solution seems to work. Hopefully, Netgear, in the near future, will develop a Windows 10 update for the WNA1000M G54/N150 wireless USB Micro Adapter.
east56user
- JamesGLSep 30, 2015NETGEAR Employee Retired
Hi east56user,
Thank you for sharing the workaround that resolves your concern. Other users might be able to do the same for their adapters.
JamesGL
Community Team- zismycat03Nov 30, 2015Aspirant
I can't get the adapter to say it's plugged in? Does anyone know how I can get it to be found by the software for windows 10? Thanks.
