josepbxt
Jul 31, 2015Follower
WNA1000M WINDOWS 10 DRIVER PLS?
I can't use windows 10 because my wifi adapter need a driver compatible with windows 10 please help...
- AdiMurthiAspirantBoth but none worked
- do you have the newest firmware for the adapter ?
- AdiMurthiAspirantCan u share a screenshot of the devices menu of yours
- AdiMurthiAspirantYes v 1.1.20
- ok. uninstall the adapter software and drivers etc
unplug Ethernet cable if you have one plugged in
open file browser, go to CD drive and right click on genie, run change compatibility to windows 7, then continue with setup - AdiMurthiAspirantOkay I'll try
- AdiMurthiAspirantBut there's no light also on the adapter
- yes I had no light also. the light will come back after proper install
- AdiMurthiAspirantProper install like the way told right
- yes.
