gcharlesb
Aug 01, 2015Guide
WNA1000M working with windows 10 !!!!
right click on netgear genie program and go to properties, select compatibility. try windows 7 or windows 8 compatibility, see which one works for you good luck !!!
DavDon
Nov 25, 2015Aspirant
I eventually got this working by using the driver only install with Windows 7 compatibility. Using version 1.1.0.20
edcoughlin
Jan 09, 2016Aspirant
Tried these methods but still the adapter is not recognized. Returning it to office supply store which is still selling this inworkable model for Win 10?
- JamesGLJan 12, 2016NETGEAR Employee Retired
Hi All,
The driver of the adapter only supports upto Windows 8.1. I'm glad some were able to make it work with Windows 10 but if it does not work then that is expected.
- edcoughlinJan 12, 2016Aspirant
Win 8.1 driver does not work for me on Win 10.
There is one listed for the non mini version - WNA1000, that also does not work.
So I had to spend $40 on a new wifi adapter. Mentioning this for others who keep trying to get the 8.1 to work and cannot...you are not alone, it does not work. There is no supported driver from Netgear.
