gcharlesb
Aug 01, 2015Guide
WNA1000M working with windows 10 !!!!
right click on netgear genie program and go to properties, select compatibility. try windows 7 or windows 8 compatibility, see which one works for you good luck !!!
gcharlesb
Aug 01, 2015Guide
also unplug your ethernet cable if you have one plugged in.
