Angry_Customer
Aug 17, 2015Aspirant
WNA1000Mv2 Not Working with Windows 10!
Muh Netgear is not werkin !!! I've been waiting so long and there is still no driver release! I've contacted technical support last month and they said to wait and check the forums. I di...
- Sep 10, 2015
On a serious note:
Same awful answer and it's been almost 3 months!
What is going on? Is something actually being done here?
Windows 10 is new but the technical preview was released to developers early.
This driver used to work on windows 8, it shouldn't take long to make the device to work with a similar new opearting system.
On the bright note:
For those who have been waiting ages, and are on the urge of buying a new a wi-fi adapter WAIT.
I found a solution!
So while I was waiting for nothing, I found out the chipset of this wi-fi adapter and it seems to be the 'rtl8182-88cu'!
1. First go to device manager
Type:
devmgmt.msc
.in run, cmd or start search
2. Then when you plug in your adapter, it should look like this! If it doesn't then unistall that network adapter which you may have ready installed.
3. Update the driver!
4. Now follow the animation below! The driver that I got was:
Realtek Semiconductor Corp. --> Realtek RTL8188CU Wireless LAN 802.11 USB 2.0 Network Adapter!
5. Profit! It should work and you should see a nice blue light on your wi-fi adapter!
JamesGL
Aug 18, 2015NETGEAR Employee Retired
Hi Angry_Customer,
Welcome to Community!
Below is the link where you can find NETGEAR adapters that works with Windows 10. We will provide an update once your adapter has an available driver for Windows 10.
JamesGL
Community Team
- Angry_CustomerSep 10, 2015Aspirant
On a serious note:
On the bright note:
I found a solution!
Type:
devmgmt.msc
- Angry_CustomerSep 11, 2015Aspirant
I felt that the animation was hard to follow. So I took the couresy to fix that.
Can't edit original post! Though I've placed the solution in a webm format, this should make it easier to follow.
Since I don't think I can embed webms here, I'll post the links to them:
Link 1:
http://webmup.com/fbcee/vid.webm
If that doesn't then follow the 2nd Link:
