tag49
Aug 14, 2016Aspirant
WNA1100 2.0.0.5 installation : intrusion detection
Hello, I have recently download and install le new version of my WNA1100. During the process, I choosed 'repair / modify', and my security system (bitdefender) alerts me on malicious detection. ...
tag49
Aug 22, 2016Aspirant
Hello,
After remove the driver / installation, clean the registery and reboot the computer, the problem is still present :-( .
The driver and the wifi key work well, but I have this message on each installation.
Tag49
JamesGL
Aug 28, 2016NETGEAR Employee Retired
Hi tag49,
Can you try to use a different computer? or disable the antivirus first when installing the adapter and enable it after the installation.
JamesGL
Community Team
