Soulres's avatar
Soulres
WNA1100 Can't Load SUPPTools.dll
Trying to newly install a N150 WNA1100 but everytime I try to run ANY of the setups, I get "Unable to load Supptools.dll " that are located in the appdata/temp folder.  I am using windows10.
  • This problem outlived the problem it was designated to solve. This was never resolved and I no longer will be watching this.
  • I have also tried deleting all files in the Temp Folder and trying again but it does not help.
  • Perhaps if someone could give me a working suppfiles.dll that'll solve the issue.
    • Soulres's avatar
      Soulres
      I have tried all,even tried installing the Original then updating to the newest version (Thats win10 compatable) Not even 4 months ago I used this on another windows10 machine with no issue. Its not the adapter either as The installer is what stops it. (Yes it is not plugged in when attempting.)
      • Soulres's avatar
        Soulres
