Spoony
Jan 31, 2018Follower
WNA1100 keeps disconnecting in Windows 10
I have this adapter since windows 7 and was working great. After upgrading to windows 10, it starts disconnecting under heavy load or torrenting. I try updating the drivers for it but each time the d...
JamesGL
Feb 23, 2018NETGEAR Employee Retired
Hi Spoony,
Is this the driver you used to install?
https://kb.netgear.com/25065/WNA1100-Software-Version-2-2-0-1
JamesGL
Feb 27, 2018NETGEAR Employee Retired
Hi Spoony,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Spoony40Mar 01, 2018Aspirant
I tried reinstalling the driver multiple times and the device just disconnects under highload with windows 10. Couldn't get it to work properly after a week so decided to use a cable and no problems now. This device is probably outdated or it just doesnt work well with windows 10.
