SeanMarshall
Nov 22, 2015Follower
WNA3100 driver is not compatiable with Windows 10
I bought the WNA3100 Wireless Network Adapter to overcome network issues I am having after upgrading to Windows 10. (The computer no longer recognizes any networks.) The download site says that the d...
jmawebtech
Nov 22, 2015Aspirant
Hi,
I am having the same issue with my WNA3100 V3, after I upgraded from Windows 7 to Windows 10.
If I go to the network and sharing center, my wi-fi adapter says it is disabled. When I try to enable it, the button still says disabled. I have tried uninstalling and reinstalling the driver with Windows 10. I get to a step asking me to plugin my adapter. I plug it in and click next. After that, I see nothing. It appears that the wireless genie is incompatible with Windows 10.
I have an Intel Xeon processor. I just received a notification today that my PC was ok to upgrade to Windows 10.
- JamesGLNov 23, 2015NETGEAR Employee Retired
Hi All,
After upgrading to Windows 10, please make sure to use the Windows 10 driver of your adapters.
http://support.netgear.com/product/WNA3100
http://support.netgear.com/product/WNDA3100v3
- WJvanEdenNov 24, 2015Star
I'm having the same problem. Sometimes the WNA3100 connects for a few minutes then it disconnects itself again. It's not just the network either, the whole wi-fi adapter says it is disabled. The only way to get it working again for a few minutes is by taking the adapter out and plugging it in again.
I think the driver for Windows 10 is highly unstable.
- JamesGLNov 24, 2015NETGEAR Employee Retired
Hi WJvanEden,
Are you using the standalone driver in installing the adapter? If not, uninstall the driver and use the standalone.
Hi JamesGL,
Yes I have, I'm using the standalone driver.
I've tried manually updating it as well through the device manager but it just says I'm using the latest driver version.
