tallbencat
Oct 15, 2020Aspirant
WNA3100 Inconsistent
Hi, I hope you are well. My WNA3100 has been inconsistent as of late, and it has been getting worse. I have tried reinstalling the software (which I did multiple times, following the instructions),...
michaelkenward
Oct 16, 2020Guru - Experienced User
tallbencat wrote:My WNA3100 has been inconsistent as of late, and it has been getting worse.
What is the problem? I fear that "inconsistent" could mean many things.
Disconnects? Goes slow? Something else?
You do realise that the WNA3100 is an ageing (2013) device that predates Windows 10?
It is also stuck with 2,4 GHz and no 5GHz.
Might be time for something more modern?
- tallbencatOct 16, 2020Aspirant
Hey michaelkenward,
I hope you are having a nice day.
Thank you for your reponse. I am actually not having this issue anymore, I turned off my device's USB sleep or whatnot and it hasn't disconnected (that's what I mean by "inconsistent") since.
I am considering buying the adapter recommended by IGN for 2020, but that is only if I'm still having trouble with my WNA3100.
Looks like it will be sticking around, at least for the time being.
the solution to this post was it
- michaelkenwardOct 16, 2020Guru - Experienced User
That's a well know issue, which is why I asked for more details.
This is where to look:
Wifi adapter properties
