David14712
Mar 02, 2017Follower
WNA3100 wifi upgrade help please
I am currently using the WNA3100 wifi adapter and I have recently started having lag issues while doing some gaming. Since wifi is my only option for internet connection I thought I would look into u...
- Mar 05, 2017
Hi David14712,
The N900 is a dual band adapter. It uses 2.4Ghz or 5Ghz for wireless connection. The 450+450 means the 2.4Ghz has upto 450Mbps link rate and same with 5Ghz connection.
For link rate description, check the KB below.
JamesGL
Mar 05, 2017NETGEAR Employee Retired
Hi David14712,
