David14712
Mar 02, 2017Follower
WNA3100 wifi upgrade help please
I am currently using the WNA3100 wifi adapter and I have recently started having lag issues while doing some gaming. Since wifi is my only option for internet connection I thought I would look into u...
- Mar 05, 2017
Hi David14712,
The N900 is a dual band adapter. It uses 2.4Ghz or 5Ghz for wireless connection. The 450+450 means the 2.4Ghz has upto 450Mbps link rate and same with 5Ghz connection.
For link rate description, check the KB below.
JamesGL
Mar 05, 2017NETGEAR Employee Retired
Hi David14712,
JamesGL
Mar 08, 2017NETGEAR Employee Retired
Hi David14712,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
