WhataPain
Oct 21, 2015Aspirant
WNA3100 Windows 7 Not Recognized after reboot
Device is not recognized after shutdown and reboot until I remove device and then plug it back it. What could cause this. Never was an issue until about 2 months ago. Now, everytime I reboot, I hav...
JamesGL
Oct 22, 2015NETGEAR Employee Retired
Hi WhataPain,
You may try disabling the "Allow the computer to turn off this device to save power".
1. Go to Device manager.
2. Look for the WNA3100 and right click then properties.
3. Click Power management tab.
4. Uncheck the Allow the computer to turn off this device to save power check box.
JamesGL
Community Team
- WhataPainOct 27, 2015Aspirant
Apologies for the late reply. Thought I had already responded to this message. Unfortunately, the suggestion did not solve my problem. All recommended tick box selections had already been selected.
- JamesGLOct 27, 2015NETGEAR Employee Retired
Hi WhataPain,
You mean you have unchecked those boxes, am I correct? If yes and still the same problem, have you tried uninstalling and reinstalling the adapter?
JamesGL
Community Team- WhataPainOct 28, 2015Aspirant
Correct. The tick boxes are NOT checked.
Yes, I’ve been unplugging and replugging in the adapter for months now to get it to function properly.
Note the following:
Wireless adapter is listed as “Remote Download Wireless Adapter”>Select>Hardware Tab> “Device Function” Names included are “Microsoft Virtual WiFi Miniport Adapter” & “Netgear WNA3100 N300 Wireless USB Adapter” (I’m thinking the “Microsoft….” Is my Bluetooth adapter but not certain. Note that this adapter had Allow Computer to turn off selected but is now deselected…. Same problem)> Select “Netgear….”>Properties>Change Settings>Power Management Tab> Both Tick boxes are deselected.
