sargunner
Feb 13, 2016Aspirant
WNA3100M Connection Problem
After trying 7 - 8 times I have installed the driver to WNA3100M N300 USB Mini Adapter and it recognise the router but there is no connection. In a prvious installation I had light in the adapter but...
JamesGL
Feb 14, 2016NETGEAR Employee Retired
Hi sargunner,
Try to install the standalone driver. If still the same, try to install it on a different computer just to isolate if the adapter is faulty or not working.
sargunner
Feb 14, 2016Aspirant
Thank you for your kind suggestions but I have tried thar without success. Thank you:-)))))
