sargunner
Feb 13, 2016Aspirant
WNA3100M Connection Problem
After trying 7 - 8 times I have installed the driver to WNA3100M N300 USB Mini Adapter and it recognise the router but there is no connection. In a prvious installation I had light in the adapter but...
JamesGL
Feb 14, 2016NETGEAR Employee Retired
Hi sargunner,
Try to install the standalone driver. If still the same, try to install it on a different computer just to isolate if the adapter is faulty or not working.
sargunner
Feb 16, 2016Aspirant
Do I use the right driver? I have installed the latest one starting with 1?
- sargunnerFeb 21, 2016Aspirant
I have now bougt another Netgear adapter - N600 -and I have still no internetconnection. This one tells me yhat i have connection to the router - also Netgear - but no internet. I have moved my computer to 1 meter from the router and I have changed channel three times. No connection. Maybe I wil lreinstall Windows 10 but I cannot see how that should help. I had a connection until a week ago but I have not found out whybI lost it. I have contacted the internet provider but I have not had any answers yet. Strange😨
- JamesGLFeb 22, 2016NETGEAR Employee Retired
Hi sargunner,
Do you have other wireless devices that can go online with your router? Please check the router and the modem to make sure that it has internet connection.
