Unknown1988
Jan 19, 2019Aspirant
WNA3100M N300 Windows 10
First time poster. I have looked through the forum but can't find any mention of this problem so far. My USB wireless adapter, pretty recently purchased, worked out of the box from day one with no ...
Nodism1125
Jan 22, 2019NETGEAR Expert
Hi Unknown1988,
Try to use the latest software version.
https://kb.netgear.com/000055955/WNA3100M-Software-Version-1-2-0-9
Unknown1988
Jan 31, 2019Aspirant
Two updates to my issues:
1 - New driver installed to my laptop with no effect, still no blue light on the USB and no network picked up by the laptop.
2 - Tested USB device on a different computer as suggested above and it has worked first time.
I cannot fathom what error there could be with my laptop that it recognises the USB as plugged in, has the latest drivers, worked previously but now does not.
- Nodism1125Jan 31, 2019NETGEAR Expert
Hi Unknown1988,
Can you connect the WiFi USB adapter to any USB port and check the Device Manager > Network Adapter if the device detected? You may check this article below that might help you.
- Unknown1988Feb 02, 2019Aspirant
Yes, the device is listed under the network adapters
