SeliO's avatar
SeliO
Follower
Jul 12, 2017
WNCE 2001 upgrade
Hi,  I have a Yamaha AV receiver, which lacks Wifi. Have seen recommendations on WNC2001, but want to know if there are any upgrades to it ?
Regards
Seli
  • michaelkenward's avatar
    michaelkenward
    It is highly unlikely that you will be able to use a wifi USB dongle to add wifi to an AV receiver. It needs all sorts of software and drivers to work.
    Try throwing the question as a Yamaha user group.
    Does the receiver have LAN input? If so you could consider powerline networking.
    Powerline Networking | Powerline Ethernet | NETGEAR
    • sktn77a's avatar
      sktn77a
      Virtuoso
      The WNCE2001 functions exactly the same as a powerline adapter but may be more limited in wi-fi range compared to the powerline adapters 'anywhere in the home' range.
