KamuiT
Oct 26, 2017Aspirant
WNCE2001 - Randomly Disconnects
I have a WNCE2001 that has been working fantastically for the past couple of years. It recently started dropping connection every few minutes and then reconnects. This is very frustrating as I work...
JamesGL
Oct 30, 2017NETGEAR Employee Retired
Hi KamuiT,
Do you have other wireless devices that works fine or has stable connection from the network?
Is your wireless network shared?
JamesGL
Nov 09, 2017NETGEAR Employee Retired
Hi KamuiT,
Can you install the device on a different computer and check if the same problem.
