rebus9
Jan 10, 2012Novice
WNCE2001 Hijacking Network DHCP
The WNCE2001 is basically a wireless bridge that allows devices that only have a copper Ethernet port to connect to a wireless network. In our case a video appliance plugs into the WNCE2001, which...
rebus9
Jan 26, 2012Novice
jmizoguchi wrote: why not show the what private IP in details you are talking about.
Why is this so hard to understand????
Our office LAN runs in 10.1.1.0/24 space.
The WNCE2001 issues addresses out of 192.168.1.0/24 with 192.168.1.251 as both default gateway and DNS server. This is SUPPOSED TO BE ONLY DURING CONFIGURATION OF THE WNCE2001.
However, once in production, the WNCE2001 starts randomly acting as a DHCP server, giving client PCs addresses in 192.168.1.0/24 with 192.168.1.251 as the default gateway and primary DNS.
THERE IS NO DOUBT. The WNCE2001 is issuing these addresses over wi-fi to devices in the office.
Moments ago I received a response to my support ticket, and the CLUELESS SUPPORT REP SAID THE WNCE2001 HAS **NO BUILT-IN DHCP SERVER OF ANY KIND**. That is CLEARLY WRONG because the WNCE2001 NEEDS to issue an IP address as part of the initial configuration process.
The difference is, IT SHOULD **NEVER** ISSUE DHCP ADDRESSES TO CLIENTS ON THE OTHER SIDE OF ITS WI-FI CONNECTION.
