rebus9
Jan 10, 2012Novice
WNCE2001 Hijacking Network DHCP
The WNCE2001 is basically a wireless bridge that allows devices that only have a copper Ethernet port to connect to a wireless network. In our case a video appliance plugs into the WNCE2001, which...
sTiNkFiZzLe
Jun 18, 2012Novice
Having the same issue. I know what is casing, but not sure why. Basiclly after a power failure or a restart the device loses its config. It then enables DHCP on the network and hijacks the network. The real issue is why does the config reset to default? Why is DHCP enabled, why not manually enter the IP into the NIC card for configuration? Is there a fix for this?
