crossbeaux
Jun 25, 2016Aspirant
WNCE2001 power led blinking green and no connection
There was another topic with this same name, but it is closed. I have the same problem, and none of the solutions listed there worked for me. The power light continues to flash green and the unit d...
crossbeaux
Jun 29, 2016Aspirant
That's the link that I did check first. Tried everything suggested and nothing works. Again, this thing is a POS.
JamesGL
Jun 30, 2016NETGEAR Employee Retired
Hi Crossbeaux,
The only way to recover the firmware is through TFTP. If it did not work for you, which means the adapter is no longer working.
