Enthanal
Sep 19, 2012Aspirant
WNCE2001 power led blinking green and no connection
Hello, I have a WNCE2001 wireless adapter that has worked for couple of months. Now, the power LED is blinking green instead of being solid... usb powered or AC plugged... I tried to access ...
- May 07, 2016
I am a Mac user and did not see any reference to how to do the fix discussed by jalloma2. However, I was able to apply this fix from a Mac.
A couple of observations.
1. I use a MacBook air without an ethernet port. I found an older MacBook pro at work that has an ethernet port and used that machine. You can also purchase a USB to Ethernet adapter at Best Buy, the Apple Store, etc. - not expensive.
2. The link to the CNET website to download the TFTP Cient has an option to download a Mac version. You can also get the tFTP client at the Apple App Store. It works!
3. When configuring your Mac, use Network in the System Preferences ("gear wheel") app. Use the same settings for IP address, etc. specified by jalloma2. NOTE: After setting the IP address manually (and be sure to turn off WiFi on your machine), I tried to ping the WNCE2001 using the Terminal utility and I could not reach the unit; message was "timed out". IGNORE THIS.
4. In the Address field in the TFTP (Send) client, use 192.168.1.251. Press "File" and navigate to where you have downloaded the Firmware and then Start. THE WNCE2001 CAN BE FLASHED WITH THE NEW FIRMWARE EVEN IF THE PING COMMAND FAILED!!!!!
5. To test the success, with wifi still off on your computer, go to "mywifiext.net" from your browser. It will open and check that your firmware is correctly loaded an correct version (V1.0.0.26NA)
Hope that helps all you Mac users out there. Would also like to add my thanks to jalloma2 for a great post. BTW, I use this unit to connect my solar panels to my wireless network for monitoring purposes.
kubrick89
Nov 27, 2012Initiate
Hi everyone... just registered because i had same problem and want to share how i fixed it:
First this to note is that, as stated in first post, blinking power led is due to firmware corruption.
To fix it you have to follow this tutorial:
http://kb.netgear.com/app/answers/detail/a_id/18989/~/router-power-led-blinks-slowly-and-router-no-longer-works
Just few considerations:
-Default IP should be 192.168.1.251 (even if your unit is "bricked"). You can check it by installing any software like fing or lookatlan.
-tftp is by default disabled in windows vista/7... just google how to enable it.
-As stated in tutorial you have to wait some minutes (2 or 3) after firmware upload to let wnce2001 to write new firmware... when it's done it will auto-reboot.
Example of command using last firmware:
Here you can find last firmwares:
http://support.netgear.com/product/WNCE2001
Hope this may help someone and sorry for my bad english :)
tftp -i 192.168.1.251 PUT WNCE2001-V1.0.0.26.img
