Enthanal
Sep 19, 2012Aspirant
WNCE2001 power led blinking green and no connection
Hello,
I have a WNCE2001 wireless adapter that has worked for couple of months.
Now, the power LED is blinking green instead of being solid... usb powered or AC plugged...
I tried to access to it throught http://www.mywifiext.net but cannot connect.
Factory reset didn't worked.
I tried to push again the firmware using "tftp -i ip@ put firmware_file" following instructions found here : http://kb.netgear.com/app/answers/detail/a_id/18989/~/router-power-led-blinks-slowly-and-router-no-longer-works
Anyone got an idea why it is doing that? what could I do to fix it ?
I am a Mac user and did not see any reference to how to do the fix discussed by jalloma2. However, I was able to apply this fix from a Mac.
A couple of observations.
1. I use a MacBook air without an ethernet port. I found an older MacBook pro at work that has an ethernet port and used that machine. You can also purchase a USB to Ethernet adapter at Best Buy, the Apple Store, etc. - not expensive.
2. The link to the CNET website to download the TFTP Cient has an option to download a Mac version. You can also get the tFTP client at the Apple App Store. It works!
3. When configuring your Mac, use Network in the System Preferences ("gear wheel") app. Use the same settings for IP address, etc. specified by jalloma2. NOTE: After setting the IP address manually (and be sure to turn off WiFi on your machine), I tried to ping the WNCE2001 using the Terminal utility and I could not reach the unit; message was "timed out". IGNORE THIS.
4. In the Address field in the TFTP (Send) client, use 192.168.1.251. Press "File" and navigate to where you have downloaded the Firmware and then Start. THE WNCE2001 CAN BE FLASHED WITH THE NEW FIRMWARE EVEN IF THE PING COMMAND FAILED!!!!!
5. To test the success, with wifi still off on your computer, go to "mywifiext.net" from your browser. It will open and check that your firmware is correctly loaded an correct version (V1.0.0.26NA)
Hope that helps all you Mac users out there. Would also like to add my thanks to jalloma2 for a great post. BTW, I use this unit to connect my solar panels to my wireless network for monitoring purposes.
- 438hpAspirantThank you jalloma2 your detailed steps worked great!
The screen shots could have been better though.
:D - mklopferAspirantI fixed this problem - My WNCE2001 unit was blinking the power LED after powering it up after a move. Here is what I did:
Download WNCE2001 WNCE2001-V1.0.0.26NA firmware from netgear and store it on my machine (unzip it so i can see the IMG file directly.
Download TftpD32 and Wireshark
Turn off my computer's WiFi, set ethernet port to IP: 192.168.1.2
Run wireshark to discover the IP that the WNCE2001 was sitting on (for me it happened to be 192.168.1.251)
Run TftpD32, use a put operation to push the firmware to the device. Set the client (in my case as 192.168.1.251:69) port 69.
Push the firmware up and wait to see if the block count goes up - if not, something is wrong, change port or IP.
Wait 10 minutes before powering off the WNCE2001 box. I thought after the transfer completed I was out of the woods as the light stopped blinking. I pulled the power and the box reverted to blinking after bootup. Eventually for me it restarted on its own and it continues to work.
Oddly, all of my old settings for my WiFi were still cached.
Hope this helps someone else! - Many thanks to jalloma2 and others who helped me to fix the blinking power LED issue!
I think the NETGEAR Support Team, whom I addressed this problem initially, could improve their skills by reading these forums.
Best regards. - glangloiAspirantWow thank you for putting up those steps to manually download the firmware. Worked perfectly!
- glangloiAspirantI'm so glad I found this forum. Thank you for listing out those steps!
- caramanAspirantI read on one of the threads about downloading updated firmware to the device but the location on the thread is now removed presumably because there is no longer support for the device. Has any one got details of how to reload the device with the new firmware?
- CalipeteAspirantKudos to kubrick89 for this solution, especially after Netgear told me it couldn't be fixed! The only addition I would make to kubrik98's instructions are to put the full path into your cmd screen. Otherwise, at least in my case, the computer couldn't find the file. For simplicity, I dropped the firmware file into the root folder and then typed out my cmd line like this:
tftp -i 192.168.1.251 PUT C:\WNCE2001-V1.0.0.26NA.img
Also, before hitting enter, I plugged the Ethernet cable into the WNCE2001, THEN plugged in the power adapter, and after about one second pressed Enter to push the file.
I thought at first it didn't work, then suddenly the light went solid yellow, then solid green! YAY! It now works! How do I know for sure? I'm posting this message through the newly fixed WNCE2001.
Hope this helps! Cheers! :)kubrick89 wrote: Hi everyone... just registered because i had same problem and want to share how i fixed it:
First this to note is that, as stated in first post, blinking power led is due to firmware corruption.
To fix it you have to follow this tutorial:
Just few considerations:
-Default IP should be 192.168.1.251 (even if your unit is "bricked"). You can check it by installing any software like fing or lookatlan.
-tftp is by default disabled in windows vista/7... just google how to enable it.
-As stated in tutorial you have to wait some minutes (2 or 3) after firmware upload to let wnce2001 to write new firmware... when it's done it will auto-reboot.
Example of command using last firmware:tftp -i 192.168.1.251 PUT WNCE2001-V1.0.0.26.img
Here you can find last firmwares:
http://support.netgear.com/product/WNCE2001
Hope this may help someone
