spitlist
Feb 04, 2017Aspirant
WNCE2001 Power LED blinks green and I cannot set it up
I see that there is already a thread on the subject and there are several links that purport to fix the problem. However these links are very long and end up being truncated so when I click on them,...
JamesGL
Feb 28, 2017NETGEAR Employee Retired
Hi spitlist,
The WNCE2001 is an adapter. Try to reset it and reconfigure. You can check support site and go to contact us if you want to have a support team to assist you.
JamesGL
Mar 01, 2017NETGEAR Employee Retired
Hi spitlist,,
Check the warranty of your device for phone support.
https://kb.netgear.com/12171/Is-my-NETGEAR-product-under-warranty?cid=wmt_netgear_organic
