StephanM
Jan 28, 2017Aspirant
WNCE2001 stopped working, power led pale red
Hi all, I used a WNCE2001 adapter to connect an Yamaha receiver rx-v 475 to my home net. All of a sudden, the adapter stopped working and since then, the power led shines only pale red. When switch...
- Apr 09, 2017
Hi Sethman,
Try to reset the adapter. Try using a different power adapter.You can check WNCE3001 or WNCE4004.
JamesGL
Feb 01, 2017NETGEAR Employee Retired
Hi StephanM,
1. Can you still access the UI of the adapter?
2. Are you getting a valid IP from the device? Can you ping the IP address of the adapter?
