StephanM
Jan 28, 2017Aspirant
WNCE2001 stopped working, power led pale red
Hi all, I used a WNCE2001 adapter to connect an Yamaha receiver rx-v 475 to my home net. All of a sudden, the adapter stopped working and since then, the power led shines only pale red. When switch...
- Apr 09, 2017
Hi Sethman,
Try to reset the adapter. Try using a different power adapter.You can check WNCE3001 or WNCE4004.
Sethman
Apr 08, 2017Aspirant
I just started experiencing the same problem. Red power light with the wall plug adapter. I let it be for a long time and it worked for a few minutes and made an internet connection. Checked for firmware update but there wasn't one. Then the power light went back to red. The manual says this means the power source isn't giving enough power but op said he tried different adapters. Is this a problem with the adapter or the plug? Any fix for this? I'm aware this is an older product, is there a newer similar adapter?
- JamesGLApr 09, 2017NETGEAR Employee Retired
Hi Sethman,
