Jimbor
Dec 30, 2015Follower
wnce2001 with static IP address?
I am using the WNCE2001 to replace a wired connection that has failed. It will connect to my video security system. To access the system from my smartpnone, it requires a static IP address for the vi...
- Dec 30, 2015
I would have expected that a static IP would be configured on the video system itself, not on the WNCE2001. Nonetheless, the WNCE2001 manual does have details for setting a static IP address on the adapter on page 13.
If you router supports DHCP address reservations, you can use that instead of a static IP address.
TheEther
Dec 30, 2015Guru
